в событиях :
Тип события: Предупреждение
Источник события: ASP.NET 4.0.30319.0
Категория события: Web Event
Код события: 1310
Дата: 29.10.2014
Время: 13:06:44
Пользователь: Н/Д
Компьютер: LERS
Описание:
Event code: 3006
Event message: A parser error has occurred.
Event time: 29.10.2014 13:06:44
Event time (UTC): 29.10.2014 10:06:44
Event ID: 9e013c87db434afbbb3e4e29296f8e8d
Event sequence: 1
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/w3svc/1213451112/root-7-130590508040156250
Trust level: Full
Application Virtual Path: /
Application Path: C:Program FilesLERSWeb
Machine name: LERS
Process information:
Process ID: 1568
Process name: w3wp.exe
Account name: LERSLersWebAccount
Exception information:
Exception type: HttpException
Exception message: Could not load type ‘Lers.Web.Global’.
at System.Web.Compilation.BuildManager.ReportTopLevelCompilationException()
at System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled()
at System.Web.Compilation.BuildManager.CallAppInitializeMethod()
at System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException)
at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding)
at System.Web.UI.TemplateParser.ParseReader(StreamReader reader, VirtualPath virtualPath)
at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath)
at System.Web.UI.TemplateParser.ParseInternal()
at System.Web.UI.TemplateParser.Parse()
at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType()
at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider)
at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders()
at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
at System.Web.Compilation.ApplicationBuildProvider.GetGlobalAsaxBuildResult(Boolean isPrecompiledApp)
at System.Web.Compilation.BuildManager.CompileGlobalAsax()
at System.Web.UI.TemplateParser.ProcessException(Exception ex)
at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding)
at System.Web.UI.TemplateParser.GetType(String typeName, Boolean ignoreCase, Boolean throwOnError)
at System.Web.UI.TemplateParser.ProcessInheritsAttribute(String baseTypeName, String codeFileBaseTypeName, String src, Assembly assembly)
at System.Web.UI.TemplateParser.PostProcessMainDirectiveAttributes(IDictionary parseData)
Request information:
Request URL: http://10.1.1.211:8989/
Request path: /
User host address: 10.1.1.211
User:
Is authenticated: False
Authentication Type:
Thread account name: LERSLersWebAccount
Thread information:
Thread ID: 5
Is impersonating: False
Stack trace: at System.Web.Compilation.BuildManager.ReportTopLevelCompilationException()
Custom event details:
Дополнительные сведения можно найти в центре справки и поддержки, в “http://go.microsoft.com/fwlink/events.asp”.
