Версия ЛЭРС УЧЁТ: 3.61.4
Обновились до 3.61.4
При попытке формирования отчетов стала возникать ошибка:
Ошибка выполнения запроса POST http://lers.xxx.ru/api/v0.1/Reporting/FastReport/Preview.
The type initializer for ‘FastReport.Report’ threw an exception. The type initializer for ‘Gdip’ threw an exception. Unable to load shared library ‘libgdiplus’ or one of its dependencies. In order to help diagnose loading problems, consider using a tool like strace. If you’re using glibc, consider setting the LD_DEBUG environment variable:
/usr/LERS/Server/runtimes/linux-x64/native/libgdiplus.so: cannot open shared object file: No such file or directory
/usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/libgdiplus.so: cannot open shared object file: No such file or directory
/usr/LERS/Server/runtimes/unix/lib/netcoreapp3.0/libgdiplus.so: cannot open shared object file: No such file or directory
/usr/LERS/Server/runtimes/linux-x64/native/liblibgdiplus.so: cannot open shared object file: No such file or directory
/usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/liblibgdiplus.so: cannot open shared object file: No such file or directory
/usr/LERS/Server/runtimes/unix/lib/netcoreapp3.0/liblibgdiplus.so: cannot open shared object file: No such file or directory
/usr/LERS/Server/runtimes/linux-x64/native/libgdiplus: cannot open shared object file: No such file or directory
/usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/libgdiplus: cannot open shared object file: No such file or directory
/usr/LERS/Server/runtimes/unix/lib/netcoreapp3.0/libgdiplus: cannot open shared object file: No such file or directory
/usr/LERS/Server/runtimes/linux-x64/native/liblibgdiplus: cannot open shared object file: No such file or directory
/usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/liblibgdiplus: cannot open shared object file: No such file or directory
/usr/LERS/Server/runtimes/unix/lib/netcoreapp3.0/liblibgdiplus: cannot open shared object file: No such file or directory
Разработчикам отправлен отчёт об ошибке.
