Обновили ЛЭРС Учет и после этого утилита Lers.ImportEnergy.exe перестала работать.
Лог работы с ошибкой:
Запрашиваем список точек учета из ЛЭРС УЧЕТ...
Произошла ошибка: 1. [Lers.ImportEnergy] Lers.Http.Api.ApiException: Could not deserialize the response body stream as Lers.Http.Api.GetMeasurePointListResponseParameters.
Status: 200
Response:
Стек вызовов:
at Lers.Http.Api.MeasurePointsClient.ReadObjectResponseAsync[T](HttpResponseMessage response, IReadOnlyDictionary`2 headers)
at Lers.Http.Api.MeasurePointsClient.GetMeasurePointsAsync(Nullable`1 getEquipment, Nullable`1 getAttributes, Nullable`1 getCustomers, Nullable`1 type, CancellationToken cancellationToken)
at Lers.ImportEnergy.ImportManager.Start()
at Lers.ImportEnergy.Program.Main(String[] args)
HResult:-2146233088
2. [Newtonsoft.Json] Newtonsoft.Json.JsonSerializationException: Error converting value "NoData" to type 'Lers.Http.Api.MeasurePointState'. Path 'measurePoints[4].state', line 1, position 6681.
Стек вызовов:
at Newtonsoft.Json.Converters.StringEnumConverter.ReadJson(JsonReader reader, Type objectType, Object existingValue, JsonSerializer serializer)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.DeserializeConvertable(JsonConverter converter, JsonReader reader, Type objectType, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonSerializer.Deserialize(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonSerializer.Deserialize[T](JsonReader reader)
HResult:-2146233088
3. [Newtonsoft.Json] System.ArgumentException: Requested value 'NoData' was not found.
Стек вызовов:
at Newtonsoft.Json.Utilities.EnumUtils.ParseEnum(Type enumType, NamingStrategy namingStrategy, String value, Boolean disallowNumber)
HResult:-2147024809
Как восстановить работу утилиты?
