Спасибо за информацию. Будем иметь ресурс в виду, но в ближайший план работы поставить не сможем. Возможно, кто-то из наших пользователей сможет заняться доработкой модуля, т.к. он выложен в открытый доступ в виде исходных кодов.
cntA number of timestamps returned in the API response
list
list.dt Time of data forecasted, unix, UTC
list.main
list.main.temp Temperature. Unit Default: Kelvin, Metric: Celsius, Imperial: Fahrenheit
list.main.feels_like This temperature parameter accounts for the human perception of weather. Unit Default: Kelvin, Metric: Celsius, Imperial: Fahrenheit
list.main.temp_min Minimum temperature at the moment of calculation. This is minimal forecasted temperature (within large megalopolises and urban areas), use this parameter optionally. Please find more info here. Unit Default: Kelvin, Metric: Celsius, Imperial: Fahrenheit
list.main.temp_max Maximum temperature at the moment of calculation. This is maximal forecasted temperature (within large megalopolises and urban areas), use this parameter optionally. Please find more info here. Unit Default: Kelvin, Metric: Celsius, Imperial: Fahrenheit
list.main.pressure Atmospheric pressure on the sea level by default, hPa
list.main.sea_level Atmospheric pressure on the sea level, hPa
list.main.grnd_level Atmospheric pressure on the ground level, hPa
list.main.humidity Humidity, %
list.main.temp_kf Internal parameter
list.weather
list.weather.id Weather condition id
list.weather.main Group of weather parameters (Rain, Snow, Clouds etc.)
list.weather.description Weather condition within the group. Please find more here. You can get the output in your language. Learn more
list.weather.icon Weather icon id
list.clouds
list.clouds.all Cloudiness, %
list.wind
list.wind.speed Wind speed. Unit Default: meter/sec, Metric: meter/sec, Imperial: miles/hour
Fields in API response
Please note that the fields present will vary based on a country to which a location belongs as well as a specific location.
name Name of the found location
local_names
local_names.[language code] Name of the found location in different languages. The list of names can be different for different locations
local_names.ascii Internal field
local_names.feature_name Internal field
lat Geographical coordinates of the found location (latitude)
lon Geographical coordinates of the found location (longitude)
country Country of the found location
state (where available) State of the found location
с бесплатной подпиской есть возможность читать данные 3-ёхчасовых срезов на глубину 5 суток.
60 запросов в минуту, 1 000 000 запросов в месяц.
Как уже @achi писал выше, проект с открытым исходным кодом, поэтому его может доработать любой желающий. На данный момент у нас нет возможности реализации поддержки данного ресурса в модуль ввиду высокой загруженности по основным направлениям.
