Перебои с опросом
Версия ЛЭРС УЧЁТ: 3.50.4
В лог попадает ошибка:
	00-f3ef17082f5f03ec3b2a5dcee6aa343f-fe50f611dd63af77-00
2023-03-20 12:01:03.1739	E:49	Microsoft.AspNetCore.Server.Kestrel	Connection id "0HMP8U37L4QSU", Request id "0HMP8U37L4QSU:00000004": An unhandled exception was thrown by the application.	1. [Microsoft.AspNetCore.Server.Kestrel.Core] Microsoft.AspNetCore.Server.Kestrel.Core.BadHttpRequestException: Unexpected end of request content.
Стек вызовов:
   at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.Http1ContentLengthMessageBody.ReadAsyncInternal(CancellationToken cancellationToken)
   at System.Runtime.CompilerServices.PoolingAsyncValueTaskMethodBuilder`1.StateMachineBox`1.System.Threading.Tasks.Sources.IValueTaskSource<TResult>.GetResult(Int16 token)
   at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpRequestStream.ReadAsyncInternal(Memory`1 destination, CancellationToken cancellationToken)
   at Microsoft.AspNetCore.WebUtilities.FileBufferingReadStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
   at Microsoft.AspNetCore.WebUtilities.StreamHelperExtensions.DrainAsync(Stream stream, ArrayPool`1 bytePool, Nullable`1 limit, CancellationToken cancellationToken)
   at Microsoft.AspNetCore.Mvc.Formatters.NewtonsoftJsonInputFormatter.ReadRequestBodyAsync(InputFormatterContext context, Encoding encoding)
   at Microsoft.AspNetCore.Mvc.ModelBinding.Binders.BodyModelBinder.BindModelAsync(ModelBindingContext bindingContext)
   at Microsoft.AspNetCore.Mvc.ModelBinding.ParameterBinder.BindModelAsync(ActionContext actionContext, IModelBinder modelBinder, IValueProvider valueProvider, ParameterDescriptor parameter, ModelMetadata metadata, Object value, Object container)
   at Microsoft.AspNetCore.Mvc.Controllers.ControllerBinderDelegateProvider.<>c__DisplayClass0_0.<<CreateBinderDelegate>g__Bind|0>d.MoveNext()
--- End of stack trace from previous location ---
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeInnerFilterAsync>g__Awaited|13_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextExceptionFilterAsync>g__Awaited|26_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ExceptionContextSealed context)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Logged|17_1(ResourceInvoker invoker)
   at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
   at Lers.Server.License.LicenseRestrictiontMiddleware.Invoke(HttpContext context, IServerLicense serverLicense, IMemoryCache memoryCache)
   at Lers.Server.Security.Authorization.AccountContextMiddleware.Invoke(HttpContext context, IAccountManager accountRepo, IUserSessionManager userSessions)
   at Microsoft.AspNetCore.Authorization.Policy.AuthorizationMiddlewareResultHandler.HandleAsync(RequestDelegate next, HttpContext context, AuthorizationPolicy policy, PolicyAuthorizationResult authorizeResult)
   at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
   at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
   at Lers.Server.ExceptionFilterExtensions.<>c.<<UseRequestBuffering>b__0_0>d.MoveNext()
   at Lers.Server.Infrastructure.RequestCompressionMiddleware.Invoke(HttpContext context)
   at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
   at StackExchange.Profiling.MiniProfilerMiddleware.Invoke(HttpContext context) in C:\projects\dotnet\src\MiniProfiler.AspNetCore\MiniProfilerMiddleware.cs:line 121
   at Microsoft.AspNetCore.Builder.RouterMiddleware.Invoke(HttpContext httpContext)
   at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)
HResult:-2146232800
Вероятно из-за этого возникают проблемы с портами опроса, они все отключатся и через некоторое время начинают работать.
Приложите, пожалуйста, весь журнал работы Сервера ЛЭРС УЧЕТ, где фигурирует данная ошибка.
Ошибка говорит о том, что служба опроса отключилась от сервера ещё до того как он успел считать полный ответ. Соответственно, часть сообщений от службы опроса теряется, и система может на некоторое время перейти в нерабочее состояние.
Обычно это говорит о том, что производительности компьютера не хватает для обработки всех сообщений от службы в пиковые моменты нагрузки.
Вы можете сделать следующее:
  • Если используется опрос по расписанию, сдвиньте по времени время опроса части оборудования, чтобы они не опрашивались одновременно.
  • Если используется опрос по подключению GPRS, ограничьте в портах опроса количество одновременных подключений. Это должно помочь снизить нагрузку на систему и убрать ошибки.
